Improving hole shot in 270FV
MDboater
Member Posts: 298 ✭✭✭
I made two changes this year that have produced a noticeable improvement in getting up on plane. First I flipped the trim tabs so that the "wings" are facing down. The following link shows how to do it. Next, I flipped the Trim-In Limit Pin on the Bravo 3. One thing to be weary of when making this mod is to be certain that your trim piston rods are clean at the tops. The piston rods will now travel about an inch further into the cylinders. I was concerned that the paint, white deposits, and assorted gunk that I had on mine would damage the seals. I cleaned the piston rods really well with acetone and a little scotch brite where the deposits were heavy.
https://www.youtube.com/watch?v=vD7zNprwuD4
I have noticed some increased vibration with the trim all the way in now when on plane. The vibration smooths out after trimming out a little bit. Any ideas of what this could be? Could it be an engine alignment issue?
I have a 2003 350 MPI engine and 24P three blade props. Yesterday I got up on plane with less struggle than before and topped out at 4600 rpms (with a more than average load of 1/2 tank fuel, full tank of water, 1/4 full holding tank and about 1500 lbs in passengers and gear). I may drop the pitch of my props in the future and/or go to a 4x3 blade combo.
Turning the tab blades was surprisingly easy. The only hard part is finding a small punch to drive out the hinge pin. The person in the video made their own. I happened to have a small enough punch in my boat tool kit. After flipping, I attached the blade to the actuator to determine the best location within the hinge. You will now be offset one hinge tooth from your previous position so you want to pick the location that is least likely to bind. There was some corrosion on my 12 year old hinge pin so I was very careful when reinstalling. I grabbed it with small vice grips about 1 inch from the hinge and tapped the vice grips with a hammer to drive in the pin.
06 Rinker 270
@reeechris, yes that will do.
@MD, fliped tabs, easy job.
06 Rinker 270
@jmichels, just to compare, what props are you running? sounds like you are right on if you get up on plane fairly quick. I'm now at 38 with the 4/3 21 pitch. the 3/3 22 pitch were faster but I would rather have hole shot, I'm going to try and pull skier this weekend. But would not even try that before.
They say the 383 produces 370 HP so 70 more that what we have.
Drool!!!
http://www.volvopenta.com/volvopenta/global/en-gb/marine_leisure_engines/AQUAMATIC/c_gasoline_sterndrive/Pages/V8-430.aspx
belleville- looks very intriguing. any more details and price?
probably way too much......lol.......would be sweet though....lighter and 430 hp
What are the standard props for the 270, 22 pitch?
Besides props what are some other ways to improve performance?
Sorry, question master over here.
06 Rinker 270
2002 270fv low swim platform
350mag 840hours
Bravo111 2.2
20 pitch 4x4 Hill Marine
06 Rinker 270
