Fresh Water Cooling
BayrunnerBayrunner Member Posts: 177 ✭✭✭
I would like to install a fresh water cooling unit on my motors - Mercruiser 5.0 MPI 260HP. Is this something I can do myself or leave it tot the pro's. Which is one of the best system to buy and where.
Bayrunner -- FV312 - Simple Pleasure
    Lot of work and a lot of parts.
    Why would you want to add a heat exchanger? Like Handy said it would be a lot of work and (I know I am going to start a war over this....lol) there are pro's and con's. If my boat did not have them I would not add them. I have had both FWC and raw water cooled and never found a difference. The con's IMO are they take up more space. Its another thing you have to maintain (clean the inside of them. Not to big of a deal but.......) and the cost of buying it and the parts to install for very little pay back............ IMO. Good luck and keep us posted..
    pault1216pault1216 Member Posts: 206 ✭✭✭
    Interesting point of view raybo3. As I search off and on for another boat, I have pretty much discounted raw water cooling considerations but perhaps I should not. I always had the impression of greater longevity with a closed system.  -Paul
    Isn't where you boat a big consideration?  That is,  wouldn't someone in salt water realize a greater benefit from FWC than someone in fresh water?
    aero3113aero3113 Member Posts: 8,843 ✭✭✭✭✭
    Yes, I would think it would be great for salt water. Really no need if you boat in fresh water. When I look to upgrade I would like to have fresh water cooled engines.
    My considerations were for primarily boating in salt water.
    I boat in salt water and there are many boats that are raw water cooled. If you have a concern about salt water just flush the engines with a shore water hose. Think about has anyone really heard of an engine block rotting out because of salt water??? Just say'n.......
    majomamajoma Member Posts: 19
    If you are in salt water and have raw water cooling, salt deposits will ruin your engines in no time. It has been proven many times.
    Not true I had an 1984 Carver with raw water cooled and that boat is still running today with the same engines. Like anything some preventive maintenance goes a long way.
    jmichelsjmichels Member Posts: 311 ✭✭
    I have seen the salt water wear out the the heads and guides pretty bad where as a fwc block would have been fine. Keep in mind too FWC engines are just for the block. The risers and manifolds still get salt water. It just saves the block.
