Generator Hose
Huff310
Member Posts: 18 ✭✭
I was at the boat this weekend and noticed that the bilge keep running so finally I open the engine hatch and noticed that the inlet hose for the generator had a slice in it. My question is what is the difference between the factory hose to a rubber steel enforced hose from Lowes? The price is a huge difference. Factory = $10 per foot and Lowes =$1 per foot. Thanks for any info.
Frodo asked a good first question that you really need to figure out an answer to. If it truly is a slice, well, that does not just "happen". As far as engine rooms, I am taking a peek in mine every single week. The more you look, the more you notice something different when there is something wrong.
Good luck Huff & hopefully you get it all figured out and enjoy the rest of the summer!
it would be a marine hose as described by Al, and when it was replaced, it would be wearing a stainless braided 'engine dress up' protective sheath.. like you can find at Summit Racing, Jegs.. ect...
I'd also keep some talc powder on board, or at least with my utilities kit, and sprinkle some of that on it from time to time... what doesn't vacuum off or blow off would give me cause to investigate...
just an idea.. :-)
It's also a wise cruiser who keeps a cone shaped foam/rubber/wooden plug/bung tied at each through hull fitting. A failure at sea can be catastrophic as recently experienced by some personal friends who were in transit last month to Key West when a fitting failed and was caught too late. They watched from the life boat as the twin masted 38' sailboat went down and was lost.
I know it seems like a protective thing Drew but anything that would hinder quickly cutting away a failing hose to insert a plug would be inadvisable. Regular inspection and replacement is the best insurance.
Here's one of many cruisers articles on handling the chaos of a fitting failure at sea.
(Dont SINK LINK)
Hope that helps. Mike
It's a wise cruiser/boater who keeps a couple of cone shaped foam/rubber/wooden plugs stowed in the bilge, preferably tied at every seacock. Wrapping a hose with a SS sleeve would work against you if you had to quickly cut a damaged hose free and insert a bung.
Had some friends who were forced to abandon ship last month off of Ft Meyers en-route to KeyWest when a hose failed and wasn't caught in time.. They lost a 38' double masted sailboat. Here's one of many interesting topics on emergency hole procedure at sea. Glad you didn't loose the boat Huff. Be safe and follow Als sage advice, buy marine grade, Mike
(Don't sink LINK)
First off, congrats on saving your boat Huff. I'd definitely follow Als sage advice and go with marine grade hose and fittings.
It's also a wise cruiser who keeps a cone shaped foam/rubber/wooden plug/bung tied at EACH through hull fitting. A failure at sea can be catastrophic as recently experienced by some personal friends who were in transit last month to Key West when a fitting failed and was caught too late. They watched from the life boat as the twin masted 38' sailboat went down and was lost.
Here's one of many cruisers articles on handling the chaos of a fitting failure at sea. The cover shot speaks volumes.....
(Dont SINK LINK)
