How does the transmission work?
rasburyrasbury Member Posts: 8,724 ✭✭✭✭✭
I have an issue and a thread going on a bravo III/350 MPI. I have had some sort of failure that most likely is a coupler. I brought the boat home last night and I am going to start doing a little look over before I take it to a shop. I have little to no experience working on motors and such, handy at best with general maintenance. Anyway, while I have read a lot I'm not convinced on the coupler and in all the responses to my posting, no mention of all as to how the transmission fits into the drive line equation.  I did find it in an engine manual.
When my failure happened, I was low speed and heard this awful metal on metal turning/scouring noise for two seconds. I quickly shut the motor off. I restarted (why I did that I'm not to sure) it cranked but no response when shifting. I also don';t recall that the engine RPM responded to moving the shifter forward and back but I was pretty freaked out. So, shut it off and anchored waiting for sea tow.  So, just brought it home and will look at all the cables and hook ups to those as well as inspect to see if the drive shaft is turning by turning the props by hand. I know the coupler is mounted to the flywheel, input shaft from the out drive goes into the coupler- where does the transmission come into play?
Best Answers
