12v or 110v?
rasbury
Member Posts: 8,874 ✭✭✭✭✭
Well, since it is almost friggin Christmas (4 months and you will be opening your Christmas present), I was thinking of getting into the local boat parade around here. I assume since I see a lot of sail oats doing this, are they running off 12 of 110?
Best Answers
MDboater
Member Posts: 298 ✭✭✭
1000 LED mini Christmas lights (~75 watts) could be powered by a small cigarette lighter inverter. 1000 of tbe incandescent version would consume about 400 watts or ~35 amps from the 12v side to power the bigger inverter that would be needed (conversion efficiency included).
I would consider using waterproof LED strip lights. You can get them for about $20 for 300 light strip and it includes a remote control and color changing capability. I think they are a little higher power than christmas lights so confirm power requirements if you go that route.
rasbury
I have a genny- I suppose I could run just about anything with that? I want to really light this rascal up! -
LaRea
Member, Moderator Posts: 8,019 mod
Definitely use the genny! Just make sure your lights don't interfere with your cleats, anchor or other safety gear.
Try running a string of lights from the bow to the top of the antenna mast to the stern. The last section (to the stern) stabilizes the antenna and keeps it from bending too much. It won't interfere with your radio reception.
Zip-tying strings of lights to the bow rail and stanchions is always good. A line around the outside of the swim platform looks nice too, but you have to attach it with tape (and then clean off the tape residue later).
In the summer, I avoid putting lights in the cockpit because they attract bugs, but you might not have to deal with that in December. -
randy56
Member Posts: 4,085 ✭✭✭✭✭
How about a blow up Santa on top of arch? I guess a blow up snow man would not be appropriate down there. It would melt.Boat Name :
