installation of camper top on 270
Just picked up my new rear camper top and frame and hardware, from TJ. The set of instructions as you will see are so wonderful, when I text TJ and ask for a beter set of instructions and where to find them, he said he did not know of any. Looked on Ameritex site, no help. I think the hardware kit is for front bimini, not the back. that's ok I can buy more hardware. And do not have any idea what the short strings are for, so I can pitch them.
So here is where I need your help. pictures of the rear attachment brackets, check measurements of brackets, picture of frame so I can tell which is front and which is back. The canvas part will be simple enough, Thank you.
06 Rinker 270
Don't have knobs, snaps only. its an older boat.
I think you only need 2 more of the surface mount hinges with pull pin and lanyard.
I have never done this before but after looking at it, I would likely do the following. Before attaching the hinges to the boat I would zipper the rear bimini to the front bimini. Attach the hinges to the stanchion ends. Verify that the frame extends to the rear of the transom such the the hinges can be attached there. Then attache the rear hinge pair centered on the boat. With the rear stanchions attached, move the front stanchions to position the front hinge pair so the the bimini top is tight. It should be pretty tight like the front bimini or else it may flap or vibrate in the wind while underway. This looks like it would be much easier with a second set of hands.
You can see a number of these rear camper tops pretty well on Yachtworld.com
Good luck!
Greg, that's an awesome response! & so quickly!...oh, that water sure doesn't look too appealing to swim in.
Cable you da man,! when't to local boat shop to buy 2 extra fasteners today, all they had was plastic, Grrrrr, so I'll get it installed, Thanks
