Enough of vacuming water in the bige
frenchship
Member Posts: 1,079 ✭✭✭
I had enough of vacuming the water in my bilge,so here what I did. I installed a small pump on the transom wall.
The pictures would be self explaining. The pump is not spark proof so I used it after running the blowers and with engines hatch open. It remove the water to the last drop
About 2 years ago I took my raw water pump that was there to wash out the cockpit connected to a seacock and disconnected from the seacock, ran the hose to bottom of bilge by drain plug. Now I just turn on the raw water pump and it draws everything out of the bilge.
you have the same type of thing going French! Very nice!
I ordered a new shower drain box for the bathroom in my 270. I kept the old one,which wasn't bad but old, with intentions of running my air conditioner drain tube into it. From what I've experienced its the only water source in my bilge. I'll post pics when I install in the fall.
Handy, I had started a topic about the whole drain plug thing. I wouldn't want something I'd have to reach on the outside transom.
http://rinkerboats.vanillaforums.com/discussion/2904/automatic-drain-plug#latest
heading to lowes in the morning to pickup a drain screen, a shower hose, a check valve and all that tubing. Thank you for this awesome idea!
but:
-no metal shower hose like you have, will prob have to just make that rubber hose
-no dish strainer
-no 90 degree elbows, but not sure they are needed on my boat, lots of room back there with the single engine.
-no check valve, which I think is the most important thing they didn't have.
Guess it'll be time to go futz around on amazon in a bit!
Just fyi anyone else wanting to do something like this, they are now making a kit that would basically do exactly this..
just need the check valve I guess!
