342 Breaker Panel lights - LED Solution!
After most of the lights burning out on my panel, I found LED replacements. Was not easy!
Found them at Specialty Optical Systems in Dallas.
Part info:
SOS 1MB-W-28
6V-28V BA9S LED White 1-Chip Dome
There is a 'shorter' bulb version, not required though. I think they were ~$5 each. It takes 17 bulbs to do the whole panel. They light up just fine, cooler and of course should last about forever.
http://www.soslightbulbs.com/
Part info:
SOS 1MB-W-28
https://www.superbrightleds.com/moreinfo/led-vehicle-replacement-bulbs/ba9s-led-bulb-1-led-ba9s-retrofit-rvb/2536/29/?utm_source=googlebase&utm_medium=base&utm_content=BA9s-x-xVAC-RVB&utm_campaign=GoogleBaseChild&gclid=Cj0KEQjw4fy_BRCX7b6rq_WZgI0BEiQAl78nd2lrvkalBeH2llgB-A4mWIQiew47h8zu9w8Rf8xbHV8aAr7O8P8HAQ
Raybo, I hear you. I guess my whole point is I may use it the entire weekend for maybe 30 seconds if at night I forgot to turn a breaker on when I got to the boat that I needed on. So, that one time I turn it on to see a breaker, then I turn it off cause I won't need to flip anymore until maybe the next day. So, not any more on/off than someone that leaves it on.
BD, I would think leaving them on overnight (at least while anchoring) would draw some power. Maybe you just do it on shore power.
Anyway, didn't mean to make a big deal either way, it's just something I don't see a whole lot of people turn on & when they do, it's just for a minute. Also have never seen anyone have them burn out. I'm sure mine will now that I'm talking about them.
Critical lighting circuits like airfield lighting systems have a slow increase of current at switch on. You may not see it but it's there by design.
https://www.amazon.com/ITC-80495-DB-Oval-Courtesy-Light/dp/B00J5JJ9UY/ref=sr_1_1?s=automotive&ie=UTF8&qid=1426095558&sr=1-1&keywords=80495-DB
http://www.itc-marine.com/product/168-wedge-base-style-led-replacement-bulb/
http://www.replacementboatparts.com/whiteoblongcourtesylight.aspx
I want to replace these Craig
http://www.replacementboatparts.com/LEDsurfacemountcourtesylight.aspx
https://www.amazon.com/ITC-69360SS-DB-LED-Courtesy-Light/dp/B00J5IOXXS/ref=sr_1_1?s=automotive&ie=UTF8&qid=1426096069&sr=1-1&keywords=69360SS-DB
http://www.apexlighting.com/boat-lights/courtesy-lights/montauk-led-12v/
