Distribution Panel switch Head Recpt
helga
Member Posts: 10 ✭
Trying to understand switches on the main distribution panel. What is the function of the Head Recpt switch? Also does the fridge in the cockpit of a Fv 342 run off the 12v or 110v system?
Best Answers
OptionsHandymans342 Member Posts: 10,375 ✭✭✭✭✭The fridge runs on both. 110 if available first and 12 volt if no 110. The head recept is for the 110 outlet below the sink. All switches are supposed to be marked as to what they control
Optionsbella-vita Member Posts: 411 ✭✭✭TV outlet is a separate breaker I added an outlet with usb in v birth tapped into TV outlet2002 Rinker FV 342
Optionsraybo3 Administrator Posts: 5,460 admin@helga the Head Recpt "switch" is a circuit breaker that controls the 110 volt outlet in the Head. In other words if you wanted to plug in a hair dryer in the head you would plug it in the outlet right under the sink.2002 342 Fiesta Vee PC Point Of Pines YC Revere MA. popyc.org raybo3@live.com
OptionsStodge Member Posts: 2,738 ✭✭✭✭Helga, the head is 12v and there is a switch on the DC side (RIGHT) of the panel for the head. The Head Recpt breaker on the AC (LEFT) side is the outlet below the sink. The lights in there are on the DC breaker for the Aft Cabin Lights. So 3 different switches for powered items in there.
OptionsIan Member Posts: 2,782 ✭✭✭✭Are the mains outlets US type - 2 parallel slots plus a round hole or the Australian 3 pin, angled slot type? (I moved here from Aus). If the former then 110 is right but the latter will have to be 240 to meet local codes. Even for an import.
