Clogged up tecma ez flush toilet on a 310 ec
gtyeegtyee Member Posts: 168 ✭✭✭
My son's friend flushed a heavy duty paper towel and now toilet is clogged. Di I have to take the toilet off or any suggestions. What are the chance it is in the maceration valve?
    ... Could be worse.  id shop vac that out and see if it comes back through. .  You may pull a "surprise "back out tho... Lol
    Had a friend remove some "female hygiene" products from the head on his boat.  He had to remove the fixture and fish them out by hand.
    edited October 2016
    I think there might be a duck bill type of anti siphon valve at the bottom of the toilet that may have trapped the paper. You should have received a Techma parts catalogue with that boat (there was one in the owner information binder when I sold it to the guy you bought it from) and if so, it should have a page with an expended schematic that illustrates where to find that valve. I think the valve is attached in-line to the white waste hose at the bottom of the toilet. Good luck. Not fun!
    While I've never had to clear a blockage on my boat head, I have seen twice now where the use of a plunger has worked very effectively - both times a gentle "plunge" once or twice worked. The duckbill valves are designed to prevent back flow and once the waste clears the duckbill valves, you are good to go - so to speak :-)
    You need to be careful with pushing a blockage into your tank.  It could end up as a blockage in your pump-out line.  If it's just paper then no problem.
  • gtyeegtyee Member Posts: 168 ✭✭✭
    Pulled the toilet off and elbow on pump has a stainer built in that was clogged, pulled it out and works like new. Easy fix
    @gtyee, AWESOME!
    Happy Times now that you $hitter is empty
    Is that Bill Murray?
  • raybo3raybo3 Administrator Posts: 5,617 admin
    Randy Quaid........... Banned from the USA because of unpaid taxes..
    Well why dont they ban Al Sharpton too?
  • Dream_InnDream_Inn Member, Moderator Posts: 7,956 mod
    Gotta love the old Nat'l Lampoon Vacation movies!
    Cousin Eddie!!!! Love it
    Holy Geez - google Randy Quaid and look at some of the Utube rants of his. CUH-RAZEEE!!!!
    LOL!  In your neck of the woods today bry1429 but forgot you put your boat away in July! Real rough ride to Hammond for gas then to Crowleys after. Seasons over but next year......
    ....that's my girl! Wait a minute, not anymore. I couldn't hold onto her! LOL
