water leak somewhere
Best Answers
J3ff Member Posts: 4,162 ✭✭✭✭✭
I'm starting to think I'm in the same boat. It seems to me that there's always at least 5 gallons of water in my bilge... can't tell if it's salt or fresh because I'm not about to taste it.. but it's troubling to think about for sure. -
rasbury Member Posts: 8,654 ✭✭✭✭✭
@J3ff you had your motor replaced and drive off- did you do your bellows? Also, on the shift cable boot, do you have a clamp of any sort on that? I'm thinking that is my issue and if so, would be a simple fix for both of us! Have not had much feed back here but in conversation with another boater, he says that would be a major source for water to come in without a clamp on it as it is under water all the time. I know yours is put up but when you get it out would take a look. I won't have mine back in the water until after the first and it's killing me to try! -
frenchship Member Posts: 1,079 ✭✭✭
Ras
no clamp on the shifter bellows will allow quit a bit of water in, the clamp is really cheap but do use the DIY tools that I send to you so you don't squeeze the clamps out of shape.or if you want try the ty-wrap system first. This will give you a fast answer if your problem is related to the shifter bellows,
Paul -
Handymans342 Member Posts: 10,375 ✭✭✭✭✭
Ras, my boat sat in the water for days and was bone dry. Drove it out for a few hours and bilge had water. Go figure -
MarkB Member Posts: 3,992 ✭✭✭✭✭
J3ff said:I'm starting to think I'm in the same boat. It seems to me that there's always at least 5 gallons of water in my bilge... can't tell if it's salt or fresh because I'm not about to taste it.. but it's troubling to think about for sure.
Use a pool salt water test strip. That will tell you right away if it's salt water.Boat Name: King Kong
rasbury said:@J3ff you had your motor replaced and drive off- did you do your bellows? Also, on the shift cable boot, do you have a clamp of any sort on that? I'm thinking that is my issue and if so, would be a simple fix for both of us! Have not had much feed back here but in conversation with another boater, he says that would be a major source for water to come in without a clamp on it as it is under water all the time. I know yours is put up but when you get it out would take a look. I won't have mine back in the water until after the first and it's killing me to try! -
MarkB said:J3ff said:I'm starting to think I'm in the same boat. It seems to me that there's always at least 5 gallons of water in my bilge... can't tell if it's salt or fresh because I'm not about to taste it.. but it's troubling to think about for sure.
Use a pool salt water test strip. That will tell you right away if it's salt water. -
@Handymans342 if you ran the a/c underway them it may be from that? It's a conundrum! Buffoonery at its best! -
Ps, enjoying your first FL " winter"? I love your area over there..if I ever hit that lottery! -
This is actually my 2nd winter Ras. Wish I had more time to use the boat. -
me to @Handymans342, 10 more years of work or 80, which ever comes first! -
raybo3 Administrator Posts: 5,563 admin
Handymans342 said:Too young to retire Ras. 10 more years2002 342 Fiesta Vee PC Point Of Pines YC Revere MA. popyc.org raybo3@live.com -
Rinker250 Member Posts: 2 ✭✭
Check Trim tabs actuators. Screws may not be sealed anymore. It happened on my 250. -
Yes, I can see tips of the screws from inside. Check the seal around cable too. Those screws and cable are just above the waterline on my boat, so leakage was not constant. -
Black_Diamond Member Posts: 5,439 ✭✭✭✭✭
Check the fitting for your bilge drain plug. Mine leaked around it. Pull and reseal. Problem gone.Past owner of a 2003 342FV
PC BYC, Holland, MI -
It doesn't take much of a leak to draw in 5 gallons of water overnight, or even a few hours. 5 gallons an hour is really only 3 drips per second.
If you want to figure out if the water is salt or fresh ... go to a pool shop and get pool water salt test strips.
rinker270nb Member Posts: 207 ✭✭✭
I always had water in my bilge and the pump would kick on once in a while, I found this drip with my phone and ears- video link is below. It's the transom plate. The video is upside down as you see it drip "up". I plan to seal the outdrive this year and try to get a ratchet on the bolts for the transom plate. It looks like it's been leaking for a while as there is a stream of it's flow. Hope this helps.
https://goo.gl/photos/TugnLaokuhP479ha9
I hope it is just a thru hull...start with the was stuff and not go to the worst case! -
Thx @BellevilleMXZ another place to look...somehow does plumbing from that go over to the motor for heating also? I took my fake lake out tho am and tests all the thru hulls and came up with zip..only possibility was the strainer for the ac, I took it off carelessly and splashed a little water- might have not been tight and dripping. That compartment has been damp in the past. I will keep an eye on that and check those hot water hoses....i am changing jobs after 21 years and will have some bot time... -
Ah.....seems to happen while running...i did run on muffs and did not see anything...will have to observe under different operating conditions..what a pita! -
Huh! as mentioned, the motor came out to do a coupler repair so perhaps something got pulled there in the process but I did not think of that- the upper deck area around the bilge area is dry- I did see some water droplets on a hose but when I wiped it off there was nothing going on with that hose and it may have been fro sloshing around....main thing is I don't want the starter to get wet and soon I will be back in salt water some and I sure don't want that in there brewing......thanks @BellevilleMXZ
Rick -
Lake_Bum Member Posts: 1,044 ✭✭✭✭
Sometimes leaks can be a royal pain when the boat is out of the water. The sheer weight of the hull sitting on the water, can reveal a leak that sometimes will never show on a trailer. I have tried flooding a bilge before, to see if the water will leak OUT as well. Never had any luck.... -
yes @Lake_Bum- it is aggravating especially when it "just appeared" after the motor came out....I don't want to put into salt water until I have this resolved! -
This is what I'd check:
- your wake coming over the swim deck if you slow down to quickly (no ways the rain channels will keep up with that amount of water).
- water from washing the boat (same as above).
- airconditioner strainer (very common these aren't on tight)
- airconditioner recirc pump, flange can get warped and leak, only 3 screws holding it together.
- through hulls.
- cold water system.
- hot water system.
- raw water system (engine cooling).
- transom/bellows.
- rainwater ingress.
Well Dream and I are tired of chasing. We just vacuum or drain -
@MarkB good ideas...the stopping I had nit considered....i have been more just pulling back the the throttle and water coming over the platform...when I slowly reduce power it sounds lil such a strain..heck that might be the whole problem. Will continue to monitor and keep that un mind. I don't want salt water down there...
