2007 280ec can you tell me the cruising speed & at what rpm?
anotherboat
Member Posts: 3 ✭
I just got a 2007 280 ec with a volvo 8.1GI eng ,outdrive with duo prop. can you tell me the cruising speed & at what rpm? what is top speed & at what rpm? I am new to a boat of this size and im learning how she works...trim tabs,eng tilt. I just love this boat. I have been out on it 5 times, just cant help throwing the hammer down all the way..someone told me the gps is the best way to tell speed, the speedometer is not as accurate,is that true? I had the gps at 44 mph, the speedometer was lower. now i want to explore.... how far can i go on a tank of gas? the cruising speed & rpm should tell me if i am getting all i can on a tank of gas correct? thanks for your help & info.
Congratulations on your new 280. I know the feeling. My boat is a 2006 and in those days and for the size of our boat, Rinker put out a performance chart that gave GPH vs engine RPM, speed and all that stuff. For us that continues to be a big help and reference.
I would avoid the hammer down all the way except of an occasional burst. All the way should give you 4800 rpms plus or minus if your boat has the right prop on it.
Your 44 GPS mph is probably correct. The water speedo will read less since that is water pressure operated and the water speedo is several feet above the transducer. Sometimes the transducer gets a load of seaweed and that makes any reading totally meaningless.
Your GPH goes up exponentially with speed. So the best economy will be below hull speed, for your boat maybe 6 mph, since economy and hull speed is related to the length of the boat that is in the water. On plane your best economy should be at the speed that keeps you "just" on plane or slightly above that. At WOT (wide open throttle,) you are really inhaling the gas out of the tank.
Since you asked about fuel economy I strongly recommend you consider installing a fuel flow meter. It will tell you all kinds of stuff about how your boat is performing and fuel usage.
I know you will get all this stuff down as you gain experience with your new boat. Have fun
Tony
Salt Shaker 342
I guess we are going for two different purposes.
I consider cruising speed to be what makes the boat feel good and me feel good. Displacement speed for me is about 7 mph. I have done a lot of that. I use our boat for traveling. On plane I guess we are going around 22 mph. The boat is happy doing that. So I have a many an hour at that speed. I think I get 22 mph at around 3500 rpms. My purpose in boating is to get it to be economical, last as long as possible and take me to places. I can make it go much faster than that but it is noisy and it burns much more gas. I have noticed I can get maybe one or two mph more by adjusting the tabs so I do that. I find if I fool with the tilt of the out drives, not much happens that is an improvement.
Everything you said is basically correct. You will get the feel after a while. The numbers (RPM's etc.) are what you will have when you get it doing what you want.
I guess I would have been a transport pilot if I would have gone that way with my life. Slow but haul lots of stuff.
What canals are you planning on traveling?
Tony
To answer your question as to "how far can I go on a tank of gas". Assuming your tank is the same size 100 gal. With 2 persons, full tank, water none, gear minimal.
at: 3500 RPM - 23 to 25 mph - approx. 180 miles
at 5200 WOT - 40 To 45 mph - approx. 100 miles
lastly
at 2000 RPM - 8 to 9 mph - approx. 170 miles (not on plane)
hope this helps.
Seguir, am I glad you came to my rescue with some numbers! I hesitated to give numbers because our boats are so different in size, hp, weight and gas tank size. I should have said a much.
But your numbers are so close to mine it is unbelievable. The only thing different is it takes my 2x the gas to do all that. LOL
Tony
Yes, it is a 2006 342. Love the boat. Had her since new. The boat and I (we) have bonded, so to speak. 900 hours total time. Just recently changed the trash XDP outdrives for the OceanX ones and since they had to remove the engines to make that conversion, I replaced them too. The originals were 280 hp on the 5.7 liter block and these new ones are 300 hp on the same block but has far more software in them than the originals. I only have 4 hours so far on these wonderful puppies. Tracks and takes off like a jackrabbit compared to before. It is a "new" boat in a 7 year old "skin."
Been to Toronto on a number of occasions during my working life. We did the Trent-Severn aboard the Salt Shaker in 2010. Would we ever love to do that trip again! Our normal cruising waters are in the Tampa Sarasota, FL area.
Tony
Getting near "hull speed" at 1800 rpms. LOL
We do a lot of 1200-1400 rpm cruising. A lot of it because of unfamiliar congested waters but even more because it is very pleasant. And as you say, the fuel burn is much more attractive.
On open water, 3500-3600 is about right for us. Puts some wind in our hair or what is left of it in my case.
Tony
Mike
