What is the black box?
Just took out my GPS C70 out and this box was behind it,it is not hooked to the GPS.2005 342.
    Looks like
    Red
    Black
    Orange
    Blk/green stripe
    Blk/red stripe
    Wht/green stripe
    Wht/red stripe
    That is you trim tab control box.
    Thanks that kinda funny that it's on the left and just handing.thanks again
    Looks like trim tab control  box, to me also. There will be a wire going to ignition switch. The newer ones have a tab on them so you can screw it somewhere.
    Looks pretty close,mine had no makings or numbers just black box  thanks for the pic
  • rasburyrasbury Member Posts: 9,011 ✭✭✭✭✭
    It's big brother watching you....
    @rasbury that's what I was thinking,satellite tracking and self destruct from the CIA.Then I though Y me I just Owen a Rinker.Well is a really cool boat.
    How do I make the discussion as answered
    I am pretty sure that I read somewhere that the box should be mounted with the wires facing down(like you have it)...
    @diggin2day1 Its just sitting in there.When I put the GPS back in I'll but some velco back there and stick it to the wall.thanks for the info.
  • Mercury2005Mercury2005 Member Posts: 141 ✭✭
    I have a new trim tab kit coming tomorrow and it has the new 'all in one' control that is part of the switch pad, large and round. Looking forward to seeing how it works.
    And yes 'diggin2day1' is correct, box must be installed on a vertical surface with wires down.
    Absolutely what diggin said about the box.     For some reason it matters.
