Remove electrical panel on 342 to replace lights
Liberty44140
Member Posts: 4,332 ✭✭✭✭✭
how is this achieved? I have a lot of panel lights out and want to replace with led. I could only get the panel out an inch or two, nowhere near enough distance to replace any bulbs which I could see were out. Obviously there is a large main power line holding it. I pulled several times with no luck, stopped so that i don't break anything. Have read here that this is a common issue on the 342 but could not find a solution. Thanks
I added a foot to the wire with a crimp connector and then did a long piece of shrink tubing over the whole thing. No way it is coming undone.
342 Breaker Panel lights - LED Solution!
https://www.superbrightleds.com/moreinfo/ba9s-ba7s/ba9s-led-bulb-1-led-ba9s-retrofit-classic-car-bulb/4/
BD- sounds like I need to keep working the panel out by carefully pullling and hopefully I can get to the point of being able to disconnect the main ac line if that will help.
Handy- do you mean an aluminum cover goes over the bulbs behind the main panel? I could kinda see that on both the 12v and 120v side when I had a peek, looked like inside behind the panel there were covers that needed to be removed to get to the bulbs.
I am no electrician so I am almost tempted to leave this alone but I have a lot of bulbs out so I'd love to replace with led. Terrified of creating a situation where I need to do more than extend the main ac, I can do that but boy there is a lot of other stuff back there! Thanks
