Remove electrical panel on 342 to replace lights
13»
    Yes it is different
    I need to do this but dread taking it all apart.  :#
    Really should look at it when I have the fridge out.
    The one in the cabinet and mic don't work waiting for handy to post a video of how to disassemble the cabinet to get it out.maybe I'll get a video camera and a drill grab a coffee and take it apart :)
    Ouch!  I removed my coffee maker in favor of storage.  Course I have yet to build a cabinet for the space.  I ended up using a hot knife to take the coffee maker out.  It was a one way trip.  I have a feeling you'd have to remove the shelf above  the Micro and Coffee maker to access them.  Not "ease access"
    Sound like a weekend project when at the dock,have plenty to do to get in the water in 5 weeks or so
    I dont video tape easy no brainer work LOL
    Handys blank switch is my blender. Stodge absolutely you should do it while the fridge is out as thats the time to un zip tie all of those wires to easily get the panel out. Renee funny story, I see you have that port window "plug" in as that port has no curtain. I didn't have one of those plugs until now...found it behind the panel when I opened it up!
    Must of been enough room to slide down behind the shelf?
    It was off to the far left where there is some empty space. No it didn't fall down, had to have been put there at some point
    Finally got it all done. Really happy with how it came out. First pic is that ground wire redone, was two loose green wires to one yellow connection, now separate yellow connectors to one terminal screw. As you can see, plenty of room for the larger led bulb. All 19 are done. Here are pics of the panel lights with the door open and closed. Like with Handys pic the pics make the lights look a lot brighter than they are, there really is not much difference from before but the pics make them look brighter. Anyway another project done. Also re zip ties all of the wires behind the fridge and reinstalled the fridge.
    Good work old man!
    Nice work you have been busy.
    Thanks gang, made an overly aggressive spring list this year....
    Nice work!
