AC Question: 270 Fiesta V
welliswellis Member Posts: 57 ✭✭
My boat is in storage and shrink wrapped, so asking for an answer on something I can't readily check.
I know my AC water pump needs to be replaced and want to shop early.
It's the one located in the bilge and is a Cal Pump. So the question is; anyone know what model # pump I may have?
Again boat is a 2005, 270 Fiesta V
Thank you in advance.
    think was a Cal pump Ms320 defender has them think I paid 125 buck?http://search.defender.com/?expression=Cal+pump+320
  • welliswellis Member Posts: 57 ✭✭
    Thanks, Yes. Cal Pump has for $135, but I found them on a pond site for $108. It's not the money I'm Just trying to verify the correct one for my boat.
    Your boat is larger and probably has a larger AC needing more gph? So you have the 320, I may only need a 225??
    Anyone out there with a 270 that can check the pump size?
    Thanks again
    That pump was for my 2002 270fv,worked find after I installed it.
    Ok thanks. You didn't say that was in a 270 and I assumed it was in your current boat. So one more question; there are cord length options. Do you recall the cord length? Or do I just splice it where I can?
    I think it was about 6' long it was tough to snake up though the floor to the a A/C because there was a zip tie where you can't cut it up under the aft bed.when you doing this make sure your A/C drains in to the shower pump.some say it drains into the bilge in the engine bay.oh yes did use butt connectors buy a/c.
    Yes mine drains into shower sump. Thanks for the info.
  • DazeOffDazeOff Member Posts: 164 ✭✭✭
    I also have a 270 and swapped mine out last season. It was Cal Pump 320 GPH Air Conditioning Pump CALMS3206B
