AC Question: 270 Fiesta V
My boat is in storage and shrink wrapped, so asking for an answer on something I can't readily check.
I know my AC water pump needs to be replaced and want to shop early.
It's the one located in the bilge and is a Cal Pump. So the question is; anyone know what model # pump I may have?
Again boat is a 2005, 270 Fiesta V
Thank you in advance.
Your boat is larger and probably has a larger AC needing more gph? So you have the 320, I may only need a 225??
Anyone out there with a 270 that can check the pump size?
Thanks again
