270 Fv arch mounted nav light (could not find an answer on the forum)
Mercury2005
Member Posts: 141 ✭✭
Replacing the arch mounted nav light with a new one. Both the old and new have three wires. I know one wire is for nav, one wire for anchor and one ground. However the old one was wired with both light wires tied together so that they both worked when the switch was on. Also according to the wiring diagram in my owners manual, it show only two wires to that light. So my question is: is the light mounted at the swim platform the aft nav light? If so it seems very low to be a stern nav light. And why does my dash switch say "nav/anchor"? Is my arch light wired incorrectly?
My arch light had three wires, the two light wires were tied together. When I put the switch in the Nav position the forward nav lights (port & star) and the arch light came on.
When I put the switch in the anchor position, only the arch light came on, not the forward nav lights. So My arch light is wired correctly with both light wires tied together and the dash switch (Nav switch) determines which lights come on.
Hope this helps.
