Have you put in Rod holders?
davidbrooks
Member Posts: 1,432 ✭✭✭✭
Gents I am thinking about adding a few Rod holders to my FV 342. Looking at ones that are inserts with covers. Any one else add rod holders to yours? If so which ones did you use and where did you install them?
Where are you fishing, for what and how?
There's options. I chose to go with a quick on/off system made by Scotty Rod Holders. They literally twist off. There are other manufactures that make similar rod holders. These rod holders are by far the most popular type on the great lakes, but that's because trolling is the preferred method of fishing.
In the first photo you'll see the rod holder base only. That's all that's left when I take them off. Easy to install and I felt easier to fix if ever someone wanted to remove them (4 small holes to fill and gelcoat).
