Heat not blowing hot air
Trying to get my heat working. It worked on a sea trial we had recently and then it was winterized again and now it's not working. Took it for a boat ride and it's still not working. I'm not sure what hole is my output for priming the system, that's the only thing I can think of. It's not spitting out any water and it did for the survey. It's a rinker 270. Any ideas?
I do this with it off, but boat in water.
http://www.tooltopia.com/mityvac-7400.aspx?utm_source=google&utm_medium=cpc&utm_campaign=paid_search_google_pla&scid=scplpMIT7400&sc_intid=MIT7400&gclid=CjwKEAjw8OLGBRCklJalqKHzjQ0SJACP4BHrqVe3dXqP_VFfnmLJIfZ_Nn3vnM3lUAbaapSx8h0R1RoCEmPw_wcB
I went to Menards and bought a bunch of different diameter / wall thickness clear flexible tubing and made adapters for the extractors so that I can use them for pretty much anything where I need to draw a vacuum:
https://www.menards.com/main/plumbing/rough-plumbing/pipe-tubing-hoses-fittings-accessories/hoses-tubing/vinyl-tubing/c-8584.htm
I use the manual extractors to change the oil in my Rinker 320 engines and generator in the fall and clean them up when done. I also use the extractor to draw antifreeze through the AC unit by placing a hose into a gallon of antifreeze and drawing the vacuum with the extractor (you have to disconnect the suction and discharge of the AC unit hoses). I use the same method in the spring to draw lake water into the AC system to ensure I have a good prime.
