Am I missing a drain at the step down by the cabin door?
Just bought a 320 cabin cruiser and we have standing water at the step down by the cabin door (also standing water behind the steering column that drains to the step down). It doesn't seem there is a drain to the bilge so the water spills into the helm berth. Am I missing something obvious?
Best Answer
    Don't have a drain in mine either, not sure if there is one.
    That's my biggest *itch about my 280. No drain outside the cabin door.
    Boat Name: Knot A Worry
    The drain on the 270 is also way up behind the helm,very hard to get to if stuff gets in there.
    @jme097 , the drain is in the corner behind the helm.
    @Cableguy Greg  Well that one yes. But if the boat isn't leaning to the starboard side then the water just puddles there. I love the 310's have that grating that allows the water to escape
    When I wash down the boat, I have to stand on that side to get the water to drain. It is a PITA.
    I learned that the day I picked up the boat when I first got her LOL
  • kingdomkingdom Member Posts: 3 ✭
    Thank you everyone for your help! Thank you Serenity for solving the issue!
    Drain is behind the helm on the other side of the boat (starboard). Yours might be clogged. Try washing down with water, but be careful not to spray all over the electricals!
  • rasburyrasbury Member Posts: 9,015 ✭✭✭✭✭
    Mine gets plugged, back flush with a hose to get the stuff moving...coat hanger works too.
  • cristykcristyk Member Posts: 29 ✭
    Does anyone have a pic where this drain is on a 270 FV 2002?
  • goalie59goalie59 Member Posts: 357 ✭✭✭
    the 320 because of it's design always leans to starboard so the drain is in the perfect spot. Although I don't think that Rinker had wanted to design it that way
    270 is also under the helm and easily clogged with leaves. You should have an inspection plate when you go down below you'll see it on the side of the helm...
