Waste and fresh water level indicator
The holding tank and fresh water level indicator only shows empty, even when the water tank is full and the holding tank must be at least half full. Has anyone experienced this in the past and what was the solution? Is it possible to get a visual on the level in both tanks, if I can't get the level indicator to work? Thanks!
@Ronpscott:
I have the same year/model. A few people have added 'windows' into the aft storage area behind the mirror (aft bunk) to get a visual, otherwise no dice on seeing them really. The sending units are from Fireboy/Xinex and are not exactly reliable. The waste tank one you can get to 'easy' from the access plate under the port seating storage area, you have to crawl in to do it. I've had success cleaning mine with The Works toilet bowl cleaner and having it work again. Xinex has a newer version out I looked at too, suppose to be a big improvement and uses the same gage/wiring you have now.
http://www.fireboy-xintex.com/liquid-level-monitors.htm
On a similar note, I don't have any indication on my waste or water tank (other than opening the engine compartment and visually inspecting). Is there a cheap way to get indication outside of the engine compartment (something that maybe works wirelessly?
Or instead of an indicator maybe just a switch that alarms at water low or waste high level?
After reading this thread I decided it was time to tackle replacing my sensors. Both show flashing when the button is pushed. Turns out mine are a three wire version. I can't find the sensors for sale anywhere online. Has anyone run into this? Any luck finding the three wire version of the sensor?
If I have to replace the whole system it seems I should be able to use two of three wires for a new system, correct?
Thanks, Ray.
Ray
2006 390
Previous 2000 340
