2005 Rinker 342 Bridge Clearance
dtwilson110
                    Member Posts: 35 ✭✭
                    I saw online that the bridge clearance is 9'8".  Does anyone know if this includes the radar that is mounted on top of the radar arch?  I have a bridge that is about 10' high that I need to clear to get to my slip.
At 10' 4" I will never make it. I guess no radar for me
That is with an enclosed array. BTW: an open array (exposed rotating type) is a waste of money on any express cruiser. Radar is line of sight, 10’ over the water limits your signal regardless of the radar power or type.
Smaller = better:
24" radome, 3.9 deg beam width
48" open array, 1.85 deg (twice the resolution)
In practice, what it means is this: if you are cruising on plane, and there's a floating object in your path, you'll have more advance warning with a bigger radar. And that has nothing to do with power.
When I sold my 342, I went from a 24" dome to an 18" dome (4.9 deg beam). The images were crap by comparison, so I upgraded to a 24" broadband. I'll ditch it and get a 48" open array at some point.
