X
Liberty44140
Member Posts: 4,414 ✭✭✭✭✭
X
Post edited by Liberty44140 on
Was the reason you had the bellows done because of a leak.
Tuff call on the swivel pin after the boats out of the water for 4 months.but I do agree they should help you out with labor and haul out. I would go the Jr Marine route.
I go in tomorrow morning got my fingers crossed as did the same repair.
it isn't a cheap service, that's for sure.
On your boat Is the transom glassed over at the top of the transom thus not allowing water into the actual transom wood as it leaks?
Sorry to hear that Liberty. You'd hope they might catch it when in that area, but does not surprise me at all. 10 years old seems to be that magic number when you have to start replacing a lot of stuff. I too had a leak (got my boat back yesterday) and ended up replacing both complete transom assemblies. For the age boat, I decided in the long run it was best to just replace it all with new. Less labor and hopefully more reliable (if there is such a thing with a boat).
Good luck and make sure you figure out where the leak is really coming from first. It's possible it's the transom plate/assembly.
I bet you'll be fine for the season.
Did they replace the actual swivel shaft? If they put a corroded shaft back into a fresh seal that would do it too.
