volvo penta y-pipe, wrong # stamped into part?
duane.mosley
Member Posts: 317 ✭✭✭
so in the process of putting my engine back into my boat, i managed to brake the exhaust y-pipe. the number stamped onto the y-pipe was 3850794. i have the tall 11'' risers. i purchased a new old stock y-pipe, same number stamped into the y-pipe, and it seems like my pipes are too low in the bilge to receive my exhaust boots. i have since let the local scrap guy have the old broken pipe so now i have no way to measure the old pipe to see if it's the same. is there a chance that the wrong part number was stamped into this part? thanks in advance.
Post edited by duane.mosley on
sad part is, if i would have waited an hour to install my engine(when i broke the y-pipe) i had a friend coming over to help me guide it into place but my impatient butt couldn't wait. the drain plug for the starboard exhaust manifold got hung up on the exhaust pipe and the weight of the engine snapped the y-pipe at the flange. i am done for the night and will get back at it tomorrow. i guess the one good thing, i live in northern ky and it's not exactly boating weather just yet. i have another few weeks before we're really able to get out and enjoy the water.
the pipe/hose you linked saved the day, along with raising the risers 2", but be aware you'll likely need to pull the engine upward some to slip the pipe/hose on... it's a pita, but it will all work out for you. also, realize (maybe not in your case?) the Y is oval and the pipe isn't.... that took some effort to get right and sealed, but it worked out in the end.
maybe i can pull the risers loose and put the hose on that way, everything is still fresh so it should come loose without damaging the gaskets. i'll try one and see what happens.
thanks for your reply 212rowboat.
