05 342 Survey Results
JPC
Member Posts: 41 ✭✭
This is my first post on the forum as I try to join the Rinker family. I've sold my previous boat and have a purchase agreement in place on an 05 342 with 350 mags, Bravo 2s and 350 hours. Today I was able to participate as the Surveyor did his work. This boat has sat out of the water for a year but is in very good condition for the most part with all vinal and interior in great condition. The camper canvas is all new from tailormaid and drive service was just performed with new gimbal bearing, bellows, shift cables, drive hoses and trim senders just completed.
My main items of concern seem to be a leaking swivel pin on the port drive and a fiberglass separation above the port motor at the 90 degree angle where the shelf is. (Picture attached). The rest of the items all seam more easily serviceable, including the engine and a/c but these 2 could be expensive later on. What are people's thoughts on this list?
. Port 350 mag loosing power when throttling up. Also feels like a cylinder may be misfiring. potential fuel issues?
. Fresh water pump not shutting off due to a large fresh water leak in the engine room above the water heater
. A/C not working. Panel comes on but no reaction to commands at the compressed unit. Blower does not come on manual or automatic. Called for heat and no compressor response or startup
. Leaking swivel pin on port drive
. Fiberglass separation on inner transom in engine bay above port drive at 90 degree corner
. Leaking exhaust joint on starboard motor. Lower section where it connects to the Y
. Port windshield wiper does not work
. Horn does not work
. Cracked port light on starboard side
. Water/oil on back transom platform by trim pumps
. Starboard spreader light not working
. No cockpit lights working
. Antenna plate cracked on radar arch
. Water overflow from A/C pan - potential clogged drain hose
. No reception on stereo for am/fm/xm
You could fix or replace the A/C yourself. You could sure the JR marine system to fix the swivel pin, and hopefully fix the engine in the boat. The rest of the stuff should be relatively easy to fix with the exception of the gel/glass, maybe some will chime in about the glass.
With a little work you might be able to get into a nice boat at a low cost.
either way good luck with your choice.
What at do you think would be a price on a fresh water boat with these concerns?
Surveyor should give you their estimated value. I'd work with that. Banks seem to favor a survey over blue book.
"Pipe Dream"
2002 Rinker 342 Fiesta Vee
2 x 350 MAG MPI Horizon Petrol
Stodge, Thank you for the tip.
JPC - good plan. The owner should take care of the engine before listing. Selling a boat with no AC or no arch light is ok but selling a boat with a mystery engine problem is not. It could be simple. My 350's have TWO fuel filters per engine so these probably do too. The PO's mechanic only ever changed the main filter and not the pre filter and eventually he had bogging issues like you do. Prefilter was black and should be white. Replaced and all was well. Your problem could be simple, but it should be the owners problem and not yours.
Good luck!
I ended up getting a thermal label maker and some white on clear tape to mark the switches once I figured them out. I'm thinking of moving the labels to the switches themselves with black on clear tape.
Still think it's kinda funny that there is a switch for the cabin "mood" lights on the helm, and another (unmarked) on the power panel.
Here is the short version.
Port engine issue resolved. Contaminated fuel, rotor cap and plugs were the issue. The owner told the mechanic "the boat hasn't run this good in years" after a test ride. He is now having the port tank drained, cleaned and refilled.
Here is the reply I received from Rinker in response to a question on the crack above the transom plate. “There is nothing to worry about. Back in the day we did not wrap the fiberglass down over the corner due to Merc wanted a 100 flat surface & that is what we did. Over the years the glass has slightly pulled away from the wood. There is nothing structural y wrong with this.”
The mechanic said the swivel pin has a small weep and is not an issue now. Will have to budget for this in a few years.
Now just waiting on the completed survey to present the remaining issues to the current owner.
While the purchase process is taking more time than I want it seems to be working with the owner correcting issues found with the boat.
