Does toilet always draw water from out side
stever3232stever3232 Member Posts: 26 ✭✭
I have a 2005 342 Fiesta Vee and I am wounding if the water for the toilet always draws water from out side of the boat or can I shut off the seacock and it will draw fresh water
Post edited by raybo3 on
Best Answers
    Answer ✓
    Far as I know, always raw water. Some people don't like the odour it can cause and just run some water in the bowl from the pull out sink hose.
  • stever3232stever3232 Member Posts: 26 ✭✭
    Answer ✓
    yes my boat is in River water if you call that fresh water
    EC 310 and EC 360 with the vacuflush draw water from the fresh water tank.
  • Dream_InnDream_Inn Member, Moderator Posts: 7,861 mod
    My 400 uses fresh water tank as well.
  • davidbrooksdavidbrooks Member Posts: 1,418 ✭✭✭✭
    Mine pulls from raw water but i am thinking about re doing the plumbing to have it be supplied from fresh water.
    Would be easy to change to fresh on a 342. Y valve the raw water intake and route under the aft bed in to the fresh water tank area on the stbd side. Watch @DanD2 video on how to get to the tank but your would not have to take thenaft cabin all apart, just open the side of the storage compartment and/or pull the ice maker which is literally 4 screws.
    @Liberty44140 Yep.  I was also thinking i could actually tap into the cold water line going to the shower.  I was going to put in a check valve and leave the raw water intake in place just in case i ran out of fresh water.
    Any time you tee a fresh water reservoir into a non-potable source...a toilet definitely is that - LOL - make sure you have an anti siphon/anti backflow valve in place to protect your fresh water source!!!!!!!
     My 270 was converted by adding a 5 gallon tank under where the garbage can is in the cockpit
