I'm purchasing a 1999 330 rinker, it has air but NO heat .
I've been told it doesn't have the reversing valve . Knowing nothing at all about cruisers, is it possible to have this added ?  Or does it require a new unit ?
  • raybo3raybo3 Administrator Posts: 5,615 admin
    Welcome to the RBOC. I am pretty sure you will need to replace the unit. I think its about $1500 to do that.
  • J3ffJ3ff Member Posts: 4,232 ✭✭✭✭✭
    Where are you located... somehow I got a 270 with no heat as well.. would be nice while its on dry dock, but I just bought an electric heater for 40 bucks that does the job..
  • sunsetsandtrailssunsetsandtrails Member Posts: 29
    Thanks raybo, I was assuming that to be the answer, just hoping it wasn't ! lol .
    J3ff , I'm in southern middle Tn. , as I stated, this is all new to me, hope I haven't stepped up to many new problems !  Thanks for your input .
    A boat always has problem
    I've heard of 16,000 btu heat and ac units as low as $900 as a diy
    edited February 2017
    I installed a 16.000btu heat/a.c. unit from King Marine air back in 1994, it's has been running perfect to this day. At the time they were the least expensive unit in the industry.
    http://www.king-air.net/
    Months later ,last week I took pics of unit . Sent them to factory, they say it has the valve. The previous owner says it never worked for him. Today going through literature , I find the panel is programmable.THe panel has 3 setting for mode, auto , Cool only and Heat only .  It was programmed for "COOL" only cycle. So I set it to auto . I'm hoping this will make it heat .
    Thanks to all for your input and answers
    @sunsetsandtrails - I bet it will.
