Kohler 5e trouble
Wildboating
Member Posts: 957 ✭✭✭
I have been reading through all the post for the last two hours but have not seen one that specifically points me in the right direction.
My 5e sometimes (often) upon startup runs a little rough and smokes, I notice the voltage is around 100v at this point then it smoothes out, raises in rpm and produces normal 110v. At this point the smoke stops and the engine runs very smoothly. I am now also experiencing the unit shutting down after 20 minutes or so. Oddly, at my dock it runs for ever when i try testing it to determine why it keeps shutting down. The last 3 times i was away from dock and needed it it keeps shutting itself off. Can anyone offer some suggestions? I put new plugs in the other day, I also pulled and checked the anti dieseing valve which seems to be moving freely. Where is the inline filter that @Black_Diamond suggest removing? Any other thoughts, I love to have our genny running when we are out. Wife loves AC, i love a happy wife.
When you run it at the dock, do you have the service panel off the sound cover? (Assuming you have the sound enclosure of course!). Mine will not run long with the whole cover on. I keep the service door off, works perfect.
Clean the spark arrestor and your sea strainer too. I upgraded my strainer to the Forespar T-150, much larger strainer and I suspect flows better too that the original one.
Second when you say it runs rough on start up do you mean it surges or simply stumbles. I have come to discover the echoke is very sensitive. You may need to either richen or lean the condition. It's always a good idea to give the carb a good cleaning. Nice and easy to remove. Just remember to buy new gaskets for reinstallation.
I will pull the cover off and find that in-line filter, remove and replace with the barbed fitting. Do you know off top of your head what size barb i need?
When I tested it at the dock I did have the entire enclosure off, I just replaced plugs and worked on the ADS. It ran forever without as much as a hicccup. The second time I went to test it after the first time it shut down it had the full enclosure on. It ran fine that test day, though I think i may of forgotten to apply a decent load (ac on) to it as i stood outside listening to the exhaust port. I will test mine with the service door off, I had not considered it may just need some more air.
Is the sea strainer the unit that comes from the center bilge in the middle of the boat? I have one there that appears to run to the Genny. I will check out the spark arrestor, Is this under the top cover?
I will pickup a new gasket set, take off the carb and do a good cleaning.
Other things I have noticed. If you run too rich it bogs down at startup and can stall. Also it tends to leave nasty black staining on the side of the boat. Not sure why. If you run too lean it surges. My best tuning so far has gotten me to one or two surges at startup and then it goes to a pretty smooth idle. Mind you this is with a brand new carb, ADS, and echoke heater.
This weekend it tan ran great except when I sucked up seaweed and disintegrated my impeller. It's always something with these things.
I also run mine at least 30 minutes every 2-3 weeks in the summer - same method as above: Start the generator, let it run at least 5 minutes, add 110v load one circuit at a time, waiting a few minutes between each load:
1) AC (or heat since I cycle my AC/Heat unit at least once a month in the summer to keep the reversing valve from sticking). Wait a few minutes, then on to the next load.
2) Hot water heater - again waiting a few minutes before adding the next load.
3) Microwave (Add a cup of water and heat it up to cycle the microwave load)
4) Turn on both burners on the stove to HI (use caution here).
5) Turn on TV's that use 110v
Run the generator at full load at least 20 minutes - usually 30 minutes.
Shed load one circuit at a time waiting a minute or two between each shed.
Once all 110v loads are off, continue running for at least 5 minutes,
Shut down generator.
This has worked very well for mine - I bought my 2008 320 new and have been doing this routine since new and have had to replace the raw water impeller three times in 9 (going on 10) seasons. Never changed a filter or plug yet (knock on wood).
BD- where are you on initial start up? Some surging, hunting or bogging or something while she warms? Less than 30 sec?
I doubt you need new plugs liberty. It's cheap insurance though to take them out of the equation.
Yes, at cold there should be about an inch or so. Also make sure the hose in bottle is all the way in the bottom.
