Boat tilts to rear starboard on Fiesta Vee 250 from 2004
Bian74Bian74 Member Posts: 3 ✭
After a plumbing break under toilet sink a lot of water was evacuated from a hull compartment under the sink, about 30liters.
BUT we think that the boat tilts to the starboard and in the rear.
There are no water i engine room.
Greatful for any answer/comment that can describe if/how eventually water can be removed from a hidden compartment in rear hull.
    Do you  have a generator?
  • rasburyrasbury Member Posts: 8,998 ✭✭✭✭✭
    do you have a forward bilge that is not pumping? Have you planned out the boat to get all the water to the back? My boat always leans!
    A slight lean or "list" is normal. Are your waste and fresh water tanks empty or full? Did you notice the list only after the leak? Is there water in the shower sump pump compartment under the stairs? I'm not sure what kind of "hidden compartment" you are referring to that could cause a significant list to starboard.
    Andy
