Depth finder
Cableguy GregCableguy Greg Member Posts: 5,074 ✭✭✭✭✭
My circa 2007ish Faria depth finder is dying a slow and painful death. Recently it has worked, then not worked. If it is shot, what should I replace it with? The sounder is drilled through the hull, so if I replace with the same style, I need one that is the same size hole, or bigger. I could go with the one that is mounted to the transom as an alternative. Has anyone replaced theirs and what did you replace it with?
