Weeping pinhole
Willhound
Member Posts: 4,242 ✭✭✭✭✭
While on a trailer and at my place (As per posts on Drive oil leak) I decided to take the free opportunity to pressure wash the hull. Doing a walk around I spotted this tiny blister. Side to side it's about half the size of my pinky nail. Can't think of what caused it, no other damage anywhere. Seems to be pushed in a bit, not blistered out from the inside. Has allowed a bit of water in though as can be seen. Panic time?
For now, I was going to let it dry a bit and seal with epoxy or 4200 or something.
fiberglass would be a better
pessimistic: someone shot your rig with a high powered pellet/bb gun or a .22 with a glancing blow.
the weep doesn't appear to be necessarily origination from the hole in my opinion, but allowing water to collect momentarily and focusing it's route south of the indentation.
if it were me, and it isn't, but if it were- I'd put a piece of clear packing tape over the hole that extends no less than two inches from it on any side- and i'd purposely put a 'wrinkle' in the tape directly below the hole (using the 'weep' as a guide) to allow moisture to escape... boom- instant one way valve and protection... then, come fall- i'd do it right.
noticed at pre inspection.
