For Any Cruisers contemplating switching over to Hill Marine 4 Blade props....
So I still come on here and enjoy reading all the info and giving input to other fellow Rinker owners although I sold mine about a year and a half ago. You guys really have a great forum and superior to alot of other ones. Alot more activity also.
I now own a 2004 Chapparal 330 Signature with twin 350 mag mpi horizons and twin B3 drives. Love my Rinker but really love this boat. The configuration is the only one of its kind. Take a look at some photos when you get a chance.
Anyways when I bought it I had trouble planing and seemed to just cavitate until it got up on plane and then was ok but seemed like it was lugging the motors only reaching about 4200 rpms. I did a lot of research and contacted the previous owner as well as Chapparal and had motors scanned and discovered the boat was intended to come with 24 pitch props not the 26 props that were on there and this mistake was made from day 1 by the dealer that sold the boat and never realized.
Long story short I did the math and determined indeed the boat needed atleast 24 pitch props to get rpms up and help with holeshot. So I went to the best, Hill Marine and discussed with them and purchased a set of Hill Marine Signature 4 Blade 24 pitch props. Ill let you read on for the results. You can read the hole thread or just skip to the end of the Summary. Worth reading. Like a new boat. Thought I would share it with you guys for anyone considering swapping props on a cruiser. Enjoy!
http://forum.chaparralboats.com/index.php?/topic/35679-2004-chaparral-330-signature-cavitation/&page=2#comment-393105
Lauren, what did you get again? and you have a bravo 3 right?
Will go do some testing tomorrow with VV running.
Couldn't do a WOT - but boattest.com had their 383 up to 5200 RPM's not sure i've ever seen mine up that high!! (However I should note that I have seen the tachometer on the boat that high, but it's not accurate in the least.)
Stats look pretty good. Keep in mind tide direction plays into effect too. I was able to do 41+- yesterday with 24p running with the tide yesterday. Running against I ran about 38 mph.
If your boat is getting up to 4800 already with props on the boat I would simply keep the same pitch and just go to a 4 blade. What is your WOT and speed on a normal day Jeff?
As I've said before, I'm not so sure I'm impressed with the 383. Would have to find a similarly loaded boat with a 350 to see what the difference is. I have heard that the 350 seems to have more power down lower..but it was just someone talking.
Props will definately help your mid range quite a bit and hole shot. You may just loose little bit on very top end. Frankly worth the trade off since most people spend most of their time cruising anyways. Go for it. You wont be disappointed.
When you place an order with Hill Marine they create the label and invoice right away but dont call for ups pickup till props are ready. Once they actually hit the road its 5 working days from then that you will receive em.
Itll be worth the wait. Had another long weekend on my boat this past 4rth and loved the new 24 pitch 4 blade. Cruised so nice and kept me on plane at low speed.
Be sure to torque em 60/100 if you are doing them your self and dont forget to be sure the thrust washers are in place before tightening em down. I ordered new ones at the same time as the props because I wasn't sure old ones would come out easily.
