2006 250 EC leans to the starboard side
duane.mosley
Member Posts: 317 ✭✭✭
title says it all, boat leans to the starboard side. doesn't matter if i'm sitting still or moving, the boat leans. while moving, i have to counter the lean with the trim tabs. holding tank was empty, batteries are on the port side of bilge. no gear under helm, no gear stored on the starboard side at all. still leans. i have also noticed that the steering wheel appears to be off by 90 degrees while tracking straight on plane.
As to the lean, is your freshwater tank on the port side, maybe fill it to compensate? Does the lean go away if you balance the passengers port and stb?
lean star
