280 trailer questions
tk1973
Member Posts: 120 ✭✭
im looking for a trailer for my 2008 280 ec and was wondering if someone could let me know the length from the bow eye to the transom. In looking at a few used ones I'm not sure the length I need.
Im assuming triple axles will be required.
And on on a side note if anyone in Ontario knows where I could grab a used one at a good price please let me know.
Im looking at an Excalibur trailer. Not sure if I should go tandem or tri axle. I'm used to tandem so will likely go that route.
Question for the ones with a 280, which bunk setup is preferred, the manufacturer doesn't set them up and I'll be on my own. Marina wants $600 to lift and set it up.
Thoughts?
I don't have trailer guide posts - important when the docks and ramps are shorter than the boat (at 32') - I can slide the trailer partially under the boat, then as I power forward the forward bunks catch the hull and help center/straighten the boat on the trailer. If it's not floated evenly (if there's a current) I'll pull mostly out, then back in until the boat just floats - and levels - then I'm good to pull all the way out and strap it down.
I use straps rated at 1500lbs - with a 4T boat you're holding the trailer to the boat, not vice versa.
I have a 270 and I tow on a tandem trailer- but I don't trailer very far and probably do a tri axle if I traveled distance or more adverse terrain. I have two bunks in the back that nest just under a flat spot on the transom that is about 8" wide and then I have a "V" in the front for the nose. The ramp I use is real steep- I don't have to worry about current on the river but wind can be a bugger. I leave just the front of the bunks out of or nearly out of the water and drive it up. It's a real challenge sometimes getting it lined up and often pushing it around to get it to settle. It's a lot of fiberglass to get on any trailer, that's for sure...
Could you buy a Trailmaster from a dealer in the states and "export" it to Canada? I am not sure if that is possible or what the costs would be.
I'd appreciate a shot of your trailer if your there. It'll give me an idea of what to look for.
It only has the 2 long bunks running on their sides.
Hoping someone one can advise me how far to space them for optimum placement for the 280.
Got this one.
that would be be helpful Greg. I sent Rinker a note asking for measurements but haven't heard back.
We pulled it yesterday and the trailer fit nice other than for having to rearrange the winch post.
Changed the gimbal bearing, checked all the bellows and they looked fine. Noticed the ujoints looked a little dry but there was no play. Couldn't see anywhere to grease them so just left them.
Dropped it it back in the water and we're good for a few weeks when it comes out for the winter.
On on a side note, I was worried about my 16 f150 5.0 pulling it. But there were no issues. Pulled it great no surprises other than for the height of the **** boat on a trailer. Had to be really careful not to take out any wires across my street.
