So I have asked this 500 times on my bellows post but no one seems to be able to answer?
rasbury
Member Posts: 8,254 ✭✭✭✭✭
ok, So I'm back to where I was the other day. This time I have a picture. I have pulled my stand away from the out drive as I thought perhaps that was causing the assembly not to move forward....I have the out drive on the studs, I put the out drive in gear forward ( I understand that with the drive off and still this far apart perhaps it is not going into gear?). I'm still able to turn the prop shaft by hand,...so, does this mean I'm really not it gear or does this mean I still don't have the drive shaft in the coupler?? I've giggled, I've kicked, It ain't going on and seems to be hitting something the way it feels.
Best Answers
Optionsrasbury Member Posts: 8,254 ✭✭✭✭✭Drive is on. It's pouring and will for the next few days....
OptionsIan Member Posts: 2,783 ✭✭✭✭I may be wrong but if I recall when my drive was off forward actually extends the shift cable. Smarter than me will confirm.
Optionsrasbury Member Posts: 8,254 ✭✭✭✭✭I ended up taking the cable off the motor, forgot to hook it back up..hopefully it went into the drive ok...
