Winterize water system and manual pump toilet.
habit68
Member Posts: 111 ✭✭
Hi gang, I apologize if its been asked here before but I couldn't find it. I understand how to get the anitfreeze into the water lines I am just not sure how to get it into the hotwater tank. I am also wondering how to winterize manual pump toilet and holding tank. I have a 2005 Rinker 250 EC (fiesta Vee)
Thanks in advance!
habit, is it the lines that go from the engine thru the water heater that you are asking about? If so, you can get pink stuff thru them if you run your engine on muffs using the valve/5-gallon approach. You can also disconnect them at the engine and drain, but not sure if all of it would properly drain out.
If you are talking about into the fresh water part of the heater, well there are several different things that people do. The first is to drain it so you don't have 6 gallons of water that mix with the pink. Then, some people just use an installed (after market) bypass and turn the switch that allows the rest of the system to pressurize without the tank, allowing the hot water lines to be winterized. Leaving the heater empty. Others fill the water heater with pink (then you can get some back in the spring).
First, yes the bypass has a valve that turns, thus bypassing it. It is something that is added in-line with a valve and small hose skipping the heater. To drain the water heater, there is typically a small knob to turn (that has a short hose attached). Turn this knob and open the pressure relief valve (usually located on upper right corner - opposite of knob) to allow water to flow. Do this after you completely empty all of your fresh water tank. Then you can either add the pink directly to your fresh water tank, or in line right before the pump and close the valves on the hot water(with it drained) and turn on the faucets. This will take probably 8 gallons or so. I don't do mine this way, but this is probably the easiest, safest, but a bit more money. I use a bypass valve, & also use an air compressor to blow the water out, then I run pink thru all but the water heater.
not to confuse you any more, but yes you need to drain the water tank first. Otherwise you will get diluted pink stuff which can freeze.
Habit, yes that sounds about right. First empty the entire fresh water tank (just opening hot and cold valves).
