JABSCO Electric Conversion 29200-0120 Quit Working
MarkB
Member Posts: 4,005 ✭✭✭✭✭
So, when I bought my boat I had them install the Jabso Electric Toilet Conversion Kit.
Has worked well, but now in our 4th season it is giving us hastles. Sometimes turns, sometimes
not. Pops the breaker for vac flush often (yes it's powered via the vac flush switch).
Anyhow, I took it apart, nothing wrong with the macerator.
Was wondering if anyone knows what is going on.
It can only be one of two things - the motor is going, or the power supply is weak.
I am thinking it's the motor, as it never gave me hastles in the last 3 years, and now all
of a sudden ....
I do realize the vac flush circuit is a bit underpowered for the electric head conversion, but it has worked
before without any problems.
Anyhow, before I go spending $500 on a new electric conversion kit, I would like to know
if anyone has any other suggestions.
Thanks.
of a sudden ....
Thanks.
Best Answers
Michael T
Member Posts: 7,241 ✭✭✭✭✭
Mark, you're a pretty savvy guy so I guess you have run a bigger gauge of "test" wiring directly from an open electrical source (battery, breaker panel) right to the entry wiring connection of your kit to rule-out a low power situation? We were having ridiculous problems with a boat HVAC system I had as in shutting off, tripping breakers - after 5 weeks of insanity it was - underpowered! -
MarkB
Well I went back to the boat and was curious as to why my jumper battery didn't budge the electric toilet kit at all. It turns out I had missed a power button on the battery. The kit turned strong when I applied the voltage. I then went back and tried it under my vac flush circuit power and it worked. So it looks like the vac flush system is a little underpowered but once it's primed the unit works fine. When I took the unit apart and reassembled it lost its prime and it took a stronger source to get it primed again. Anyhow it works now. In fact it works better than before. Could also be that the force of the direct battery worked the unit in so it runs smoothly now.Boat Name: King Kong
MarkB
All fixed. Needed to run a 10 gauge wire directly from house. The vacflush circuit just couldn't provide enough juice for this kit. It now runs fine.Boat Name: King Kong
I think I'm going to replace it and if it doesn't work, well it has to be the power supply and I will get my mechanic to fix the over the winter.
Just not sure it's worth the hassle and if the re-build kit will get rid of the noise. Or just go back to manual.
I would rebuild it. I sold my boat, but after I fixed it (and the main issue was running a 10 gauge wire directly from the house battery) it worked like a charm. I did open it up, and reassemble, which helped. I wouldn't go back to a pump system.
http://www.xylemflowcontrol.com/marine-and-rv/electric-toilets/58500-series-lite-flush-toilet.htm
Do you think it will fit? I know they say the footprint is the same. Wondering how to get to beneath the toilet to secure the bolts.
As well, wondering how do you guys run wires to this thing? I'm a bit of an electrical noob so any assistance would be appreciated. I know I've read the breaker for the vaccuflush is what most people do but at the risk of not enough amperage. But it looks like the closest and easiest thing.
http://rinkerboats.vanillaforums.com/discussion/3038/280-ec-wiring-diagram#latest
As as far as accessing the bottom of the toilet. Would I have to remove this panel under the head to gain access? Don't really see any other way
