Rinker Fiesta vee with twin Mercruisers 8.2
cloe00
Member Posts: 9 ✭
Hi,
We ran out of gas on our 2005 Rinker Fiesta vee with twin mercruiser 8.2 engine, and when we put about 10 gallons of gas on each engine (we brought the gallons to the boat), it now would not start, seems like the engines have some air going thru them. What can we do to start the engines back?
Best Answers
Optionszaverin1 Member Posts: 1,672 ✭✭✭I would prime the fuel system
statrting with checking and filling the fuel filter
I also had great success with priming boats by starting them on a remote fuel tank.
sometiems you have to prime them via throttle body or if it’s really bad pressurize fuel rail
and start bleeding it -
Optionsjmichels Member Posts: 311 ✭✭You can just remove the feed line coming from the fuel filter pump housing to motor and bleed it until fuel starts coming out into a cup then tighten it back up. Or alternatively fill fuel filter but sometimes that won't work.
also never use starting fluid !
