Size of Portable Generator
Willhound
Member Posts: 4,183 ✭✭✭✭✭
The only experience I wasn't able to accomplish in our first season as a cruiser was a true overnight on the hook. We spent about 20 nights out, but always at a marina or slip with hydro. All because the Admiral is a bit of a nervous sort and has an insane fear of all of our batteries going dead and us being stranded, even though I've patiently explained how the battery switch with separate battery banks works and how we reserve the starting battery for starting only.
So....my only other alternative is to pick up a portable generator/inverter as a back up.
I know there is a whole other discussion on the safe use of portable generators on boats, I've got my head around that.
My question is, I have a 3 bank 20 Amp ProMariner Prosport onboard battery charger that is rated at full draw for 20 amps, so at 110V, about 2200 Watts. Specs below.
The generator brand I am considering is available in either a 1000W (900 Continuous) or 2000W (1750 Continuous) both at 15 amp of course (well, probably actual is around 13.7 I would think).
My preference is the smaller unit based on weight and size. Slightly cheaper too, but that's not the primary consideration, the difference is only a couple of hundred bucks. My cooktop is electric and draws 1500 watts, so the smaller gen wouldn't allow us to use that on the hook, but we're ok with that, always have a BBQ with us.
So my long winded question is, will the smaller unit be adequate to feed the charger, even if it takes longer to charge? Or do I need the 2000 Watt model to not cause issues with the charger? And for those of you that have/are using portable gen's, what are you using?
"Knot Quite Shore" - 2000 FV270
@Cableguy Greg I like a lot of the Ryobi stuff and I like the wheels on that too.
The brand I'm considering is a Kipor. We have a relationship with them at work, so can get a unit at pretty much cost. A Chinese copy of a Honda, but at less than half the cost. In fact, I believe I read somewhere that Kipor manufactured the early Honda Generators before Honda got their own plant up and running.
Either of you have thoughts on the 1000 vs. 2000 thing?
Be mostly to keep batteries topped up.
You buy her a paddle. lol , a 270 is slightly harder to paddle than a canoe.
RenneChris - Are you saying that you can go 36 hours on batteries on the hook between charges? Both fridges running? WOW! How are your batteries set up? 4 batteries?
I'm going this route and if my math is correct the 300W panels should be enough to keep up with the fridge being run year-round.
My optima starting battery is less than a year old and pretty weak.. def not going to do that again.
In all seriousness - there are a few concerns with leaving the genny going while driving. Ours shut down if we hit any considerable bumps - the carb wasn't designed to be mobile. We remedied that by converting to propane. I've heard stories of calamities that ended in fire and one guy electrifying their tow vehicle, but if you install it properly and use a little common sense you shouldn't have a problem.
