Changing out toilet on my 270
bigfirk08bigfirk08 Member Posts: 1 ✭
does anyone know how to access the lower nuts that hold my toilet down? I can't get to the to remove and replace the whole unit
    Remove the small cabinet that is under the sink.
    Sounds like a crappy job lol
    Boat Name: Knot A Worry
  • gizmogizmo Member Posts: 3 ✭
    Any other tips?  I removed the cabinet, but my normal adult male arm barely fits in far enough to reach the closest bolts, let alone the ones holding down the pump assembly that are a foot further back....
    Here is what you do
    Drill a hole using a hole saw and gain access to remove and install.
    Cover the hole with this
    How do I know?
    lets just say I replaced my toilet last spring lol
    Was going to be my suggestion also.
    Thanks, that was what i was thinking was going to have to happen, but was undecided as to how to cover the hole afterwards with something that would seal well.  What size did you hole saw...5-6"?  And where did you source the hatch?
    Twist hatches can be bought at your local west store or online.
    whatever size Will fit your hand.
    Never mind, google answered both questions.  5" sea sense hatch cover....
  • 99270fv99270fv Member Posts: 94 ✭✭
    i used 2 wrenches taped together for length to reach the nuts on the bolts
    On my 280 there was no way I could reach anything
    thats why bowl was replaced but main base was old and cracked.
    If/when I replace my toilet, it is going to be this one. It has the same bolt pattern as the manual flush toilet.
    https://www.westmarine.com/buy/jabsco--lite-flush-electric-toilet--P011015401?recordNum=3
    Most toilets have same mounting pattern. That’s soecially true if you stick with same brand.
    owner before me replaced the upper bowl but not the base. Reason was getting to the nuts under the fibgerglass enclosure.
    one other trick is to cut the tops of the bolts off and use as screws with marine silicone to secure the toilet to the glass.
