Who knows jet boats?
Liberty44140
                    Member Posts: 4,414 ✭✭✭✭✭
                    the admiral would really like a jet boat for next summer so I’ve been looking around for one. 16-18 ft arena, early 2000s. Would prefer a single engine but it seems most have twin. Anyway almost all of of them have had the oil injection pumps disabled so they are now premix fuel manually.  Anyone know why that is so common? Just too expensive to fix? Thx
I have to disagree with Handy though as far as pre-mix running better. A properly set up and maintained oil injection system works fantastic and provides the correct amount of oil for given RPM/operating conditions. Way, way back in the early 70's when injection first came out, they were less reliable and many people by-passed them, but to do so in this day and age is the sign of a lazy or un-educated mechanic or an owner that liked taking short cuts on maintenance. I've owned at least 10 snowmobiles, 4 motorcycles and a few boats with oil injection and have never had an issue. If I came across a newer piece of equipment with the oil injection disabled, I'd probably walk from the deal. If they took a short cut on that, what else did they take short cuts on?
shoot questions at me
v6 converted to premix. Reason behind that is top end blows up if pump goes.
anyway I would rather invest into a nice center console rib but jets are fun. Here in lsc you can run in the flats where others boats can’t.
electrical is most common issue.
Always check compression on 2 strokes before purchase. Anything 110 or lower or uneven numbers run
pump needs to be removed
- SeaDoo SuperChargers - need annual maintenance or it fragments itself and the small ceramic bearings tumble into the intake and grind away the engine as part of the lubrication system.
 - SeaDoo Valves: Sodium filled (lighter, higher reving), but they tend to rust out where the exhaust allows moisture in
 - SeaDoo pumps: Smaller for better holeshot, but as they come out of spec they dramatically drop power.
The Yamaha's, however, are typically lower performing twin engines. They're dirt simple, lower compression, heavier construction, and tend to last a lot longer. You'll find a lot of SeaDoo's under 400 hours, but not many running over that (without a rebuild). You'll find many Yamaha's for sale with 1000's of hours, still running. You'll pay more for the Yamaha, but I really feel they're better craft.Jet drive vs prop: horrible economy, can't run as shallow (without sucking up debris), can't plane on one engine, can easily clog with debris, you will have to dive under the boat to clear it out (vs raising the drive and staying dry), and the self-draining scupper design almost always leads to water in the boat. When it was cold I'd plug the scuppers and pray I didn't take a wave. I was happy to transition to prop drive.
Just my 2 cents.
Here is a mostly boring video of me cruising around one of the lakes in the chain we were on. A couple spinouts later in the video.
-=Mike G.
2014 Rinker 260EC
Carbs = it's 90% getting the right pop off pressure and sync. That can take some work, and isn't the easiest.
RAVE: keep them clean and my bed.
Jet: you'll almost undoubtedly have to pull the pump, shaft, foot, and re-bed it. They ALL leak after a few years. Replace the carbon seal with a grease seal, machine the shaft to work with the new seal, and put a couple pumps of grease every month. Without that I would wager it'll cavitate within the first 10 hours you run it, if not when you buy it.
I made money in college buying these running rough, tuning them, and selling them. Properly cared for - they'll give the 18' supercharged 4-tec a run for the money. They'll yank twin slaloms up, easily pull a skier/tuber, and put you in the seat.
chexk compression prior to purchase but no answer your question yes it will pull a skier
Zav we did compression, was good at just over 150 on each and within 1 or 2 psi. Used a cheap auto zone rental and got weird readings at first but then gave it a quick final turn in the hole with pliers and it tightened up and gave good readings. Forgot to open the throttle for the test but from what I read that rarely makes a difference and would only make them a little better.
thanks again!
Admiral is a very happy camper that she has a jet boat and the captain is very happy that he made her happy for under $3k
those are good numbers
anway convert it over to premix and you will be solid for years to come
never trust oil pumps
if stored inside always leave the engine hatch open
those things hate humidity and moisture
electronics that is
