Power inlet bad?
MiamiAG
Posts: 210 ✭✭
Hi,
No shore power. Every time I connect the cord to the shore power inlet the main breaker trips. Any way for me to make sure it's the inlet that's bad before buying a new one? Thanks!
2013 290ec
I also tries another pedestal and the breaker tripped too.
Id highly recommend you check with a marine mech. Theres very little room for error in this issue. Good luck. Mike
I think it's got to be a bad inlet or bad main boat breaker.
What voltage and amperage is the shore power? Is there anything onboard that has selectable voltage? Does the power invert/convert at a central location or each individual device (if its selectable at all, or if it converts/inverts at all)?
