Speedo tube on bravo III twin engines
Do both tubes have to be connected to each drive for the speedo to work?
    Usually comes off 1 drive. Does not need 2.
    Yes one drive
  • onislandtimeonislandtime Member Posts: 309 ✭✭✭
    I thought so. I can unclog one drive but the other won't give. Stuck drill bit all the way in and compressed air wont blow through
    Put a drill on that bit
    Ye most of the time it’s on the drive side.
    when i had drives serviced they cleaned out the passage.
    if you go into sandy areas your chances are pretty good to clog it within the same season.
    i just use my gps actually.
    if I see accurate mph I know how my boat is performing. In other words I know where I need to be to plane and cruise and that changes With load but mph needs to stay the same.
    You can always get a digital gps one and forget about the speedo tube forever
    I have chartplotter and vesselview lol. Since the drives were off I thought I would clean then out. Hate when something isn't working on the boat!! I know it wont last long lol
    yes starboard side is the one. when my drives were of last winter I soaked them for days to get it cleaned out. thin piece of wire going down from the top did the trick. shop vac got more out then compressor.
