Speedo tube on bravo III twin engines
onislandtime
Member Posts: 309 ✭✭✭
Do both tubes have to be connected to each drive for the speedo to work?
onislandtime
when i had drives serviced they cleaned out the passage.
if you go into sandy areas your chances are pretty good to clog it within the same season.
i just use my gps actually.
if I see accurate mph I know how my boat is performing. In other words I know where I need to be to plane and cruise and that changes With load but mph needs to stay the same.
