FV270 dash ground block?
cassiolacassiola Member Posts: 43 ✭✭
Thought I saw a post where someone said there should be a ground block behind the dash?
I've looked and cannot find it.. my goal is to add an accessory switch.
Seems straightforward to add power to my switch:
But having problem locating where I should run the ground wire to? I couldn't locate a ground block...This is all I could find where all the other grounds go to:
Does this mean I'll need to run a ground directly to the battery?
