FV270 dash ground block?
cassiolacassiola Member Posts: 43 ✭✭
Thought I saw a post where someone said there should be a ground block behind the dash?
I've looked and cannot find it.. my goal is to add an accessory switch.
Seems straightforward to add power to my switch:
But having problem locating where I should run the ground wire to? I couldn't locate a ground block...This is all I could find where all the other grounds go to:
Does this mean I'll need to run a ground directly to the battery?
    I’ve been behind the “dashboard” of my FV270 more times than I’d like to admit... don’t remember ever seeing a ground block. I always tied into an existing ground wire... just remember that the salt water environment makes “shotty” connections fail much quicker than behind the dash of your car.... solder and Shrinkwrap!
    I have a junction block and three network junctions mounted to a piece of Starboard that is screwed to the back wall.  It helped me organize wires, and it also prevents these components from getting bumped around.  It still looks like a rat's nest, but it's much better than it was.
    Originally, the junction block was just hanging loose inside the helm, wrapped in electrical tape.  Maybe yours is like that.
  • raybo3raybo3 Administrator Posts: 5,615 admin
    Why do you need to add a negative to a switch? Hot leg and switched leg. If its for a light indicator just tap the negative off the switch next to it........ Just say'n
    @LaRea is that a NMEA2000 hub?
    It's SeaTalkNG, which is Raymarine's version of N2k.
  • cassiolacassiola Member Posts: 43 ✭✭
    Thanks everyone. Looks like I'll be adding a ground block and running that back to the battery. Was just hoping I was overlooking some dark corner.
    @raybo3 sorry, I didn't mean a negative for the switch but for the accessories that will be connected to that switch.
    @LaRea that looks much cleaner than what I see behind my panels!
