Exhaust shutter project
Liberty44140
Member Posts: 4,338 ✭✭✭✭✭
plan for today was to change all 4 exhaust shutters on my 350 mags. It didn’t happen. I could not for the life of me get them apart. There is zero corrosion or rust, I am fresh water, but could not budge the exhaust elbow. I did use a hose pick to get the boots separate, I could wiggle it, but no dice. Thinking I may just pay a mechanic to go change them. Thoughts?
Ras- what do you mean by paint saved?
New plan - I am going to try to use the hairdryer method this weekend to slide the boots down. Any other ideas on sliding the boots down? dishsoap & water? I wont spend the $120 in gaskets because it wont be much more to just pay someone to do this.
use dish soap. when its wet it's slick, when it dries it's sticky... meaning, you can get them off easier and reinstall them easier, but when it dries you dang near don't require the and clamps (by law you do, and by any reason... i'm just saying they stick a lot better)...
so here are the tricks:
1. remove or loosen ALL the clamps on the boot. dip a plastic knife in dawn soap and slip it between the boot and the elbow on both sides.
2. don't try to slide the boots up or down yet... simply grab them with both hands on either side, and twist them left and right... you're taking advantage of the slight bend shape in their form. when it twists/turns, it will open a small gap on either side.. add water (which will mix with the soap already in there from the knife)
3. twist some more.. when it starts to turn easily, and it will, simply push rearward toward the Y pipe as you're still twisting. there ya go.
noise at idle or other work being done
You usually hear a tick when rubber wear out down to metal.
other would be a severe over heat condition that just melts the flaps.
checking flaps would make sense to make sure they are still there.
not having flaps can cause a hydro lock
