2001 Fiesta Vee 242 Prop and Wiring access questions
paulpwipaulpwi Member Posts: 5 ✭
I just purchased a 2001 Fiesta Vee 242 and it needs a new prop.  The Engine is the 240HP Alpha 1 5.7L EFI.  I want to put a SS Prop that will perform well.   It does have trim tabs.  What is the best size prop for this boat?    Also I need to install a GPS/sonar (model below) and haven't yet figured out how to get access to the wiring access along the side of the boat.  Any help there would be great.
Humminbird HELIX 9 CHIRP MEGA SI GPS G2N
    For the prop I'd start with the size/pitch of your current prop.  You should be able to see that on the prop.
  • paulpwipaulpwi Member Posts: 5 ✭
    Nope this aluminum prop has been reworked several times and its not readable.   The owner said it was the original that came with t he boar.   It has low hours:)
