Collapsing Holding Tank
 kordo
                    Member Posts: 245 ✭✭
kordo
                    Just discovered that the vent fitting on my holding tank was too small for the hose.  My boat is a 2011, so it looks like it came from the factory that way.  Lots of sealant and the hose was compressed way too much due to the smaller diameter of the fitting.  I suggest others take a look at the vent fitting.  If it's too small it might contribute to the holding tank flexing too much or even collapsing when pumping out.  I noticed the same thing on my fresh water tank vent fitting but since there is no need to pump it out, should not be a problem.
Also, in many of the electric pump models and conversions (like mine) the set up doesn't allow air back through the pump body to the tank. Even a manual head, if in the lock position will sometimes create an air lock and not allow air back. Our pump out operator took the time to check what kind of head I had, and even with him taking it extra slow I can see signs that the tank has been flexing and will be adding an additional vent to the tank before the first pump out this season. Should be a stock item from the manufacturer in my opinion.
That is because it is only connected thru the original vent line. So, it can only maximum vent as much as the original vent line allows without a filter.
I have at least 25 acquaintances who have been using Big Orange since its inception. None, to my knowledge have ever had waste tank damage after the installation.
Yes, I added a tank saver but I know that was overkill and I'm just ocd about that stuff.
An excerpt from the Big Orange web site makes it sound like the filter itself is bypassed, but does not have external vent. You are much better off adding the additional tank saver:
"Special By-Pass Valve
A potential danger of traditional vent line filters is that your holding tank could collapse when being pumped out. This happens because as the waste in your holding tank is removed, air must enter the holding tank. The way the air comes in is through the vent line.
Since the air needs to go through the filter, it is not able to come in as quickly as the pump is removing stuff from the tank. This causes the pressure to become unbalanced and the holding tank will collapse. It’s as if you were to suck the air out of a plastic pop bottle. When you suck the air out you decrease the pressure inside of the bottle, causing it to collapse.
The Big Orange Original Filter reduces this possibility by including a special by-pass valve to effectively "turn off" the filter so that you can empty the holding tank with no chance of collapse due to filter restriction."
MT, as far as 25 acquaintances having it, I know at least that that don't have it and never had an issue with collapse either. I think we both know that it's a matter of the owner being aware and preventing the collapse issues.
https://www.homedepot.com/p/Eastman-1-2-in-MIP-Vacuum-Relief-Valve-60156/300702609
@Willhound , what pressure is the relief valve set at? It looks like something I'd be interested in adding to my homemade filter as well, although I'd think mounting it on the bottom, nearest to the tank would give you best relief. I say that because then the relief would not have to go thru the filter when needed. Or, if filter is clogged, it can still provide relief. (all this relief talk, I may have to go pr...oh, you get the point )
Dream, the max psi is 150. That is before she blows. For air intake it takes little force to open it.
Opening pressure is almost zero. Max pressure on mine is 200psi and promises to move 15 cfm at 2HG of pressure.
https://m.homehardware.ca/h5/m/en/r/hh/en/rec/index.htm/Plumbing-Electrical/Plumbing/Waterworks/Water-Heaters/Accessories/1-2-Vacuum-Relief-Valve/_/N-2pqfZ67l/Ne-67n/Ntk-All_EN/R-I3284653?Ntt=Vacuum+relief
